Ok so here's the deal.....This is nothing more than documenting quality, performance and service from a source who's plane is the 'biggest" yet. It is well known this particular source supplies other vendors but we will keep it limited to the "original" source supplier: Peak Models.
I ordered the 32% Extra 330SC on 4/5/15. Will do the unboxing /inspection when it arrives.
I will do the assembly, installation, modifications (if necessary) and maiden. The following is a list of components that will be used;
1) DA70 twin cylinder engine.
2)Pro Flow large canister. (wont fit.....read on.....)
3)DA 2n1 header.( Modified.......read on.....)
4)Falcon 25x8W prop.
5) Blue Bird BLS 3114 servos all surfaces BLS 2209 on throttle.
6)Turnigy Nano Tech 4200mah hard-case Li-Po.
7)PAU No Limitz 4.5 inch fiberglass Ultimate spinner.
8)Smart Fly Ignition regulator/kill system.
9)Futaba R6014FS receiver.
10) Small Black fuel dot.
11) Miracle Black charge switch.
12) H9 Black servo arms.
13) TerryCustoms Motor mount. (Copied his idea...Thanks Terry)
 Will start "cooking" when it gets here!
 I hope it does not fold up like my YS Rocket Ship did!
