TLFMM
Do I understand the right way : you are still working on a constant Speed for engines 210 ccmLet me work on that one!
and more ?
Thanks for the detailed information and comparison.
55 lbs. is pretty light for a 50% plane.
Have you checked the thrust numbers on the Valach 210?
It would be nice to see a video with someone putting the prototype in a hover and doing a full power climb-out.
I know - not truly "scale" flying, but it does immediately show the available power in the system.
Let's see - all we need now is a constant speed prop.
Oh, did I mention EFI, and onboard starter, too?!
The Valach 210 with Fiala 36X14 Prop, produces about 100lbs of static thrust.
Almost 2:1 Now were talking!
At 187 km/hr that would be 116 mph. Can that be correct?
Running the numbers assuming a 2-Blade prop, 36 x 14, your tip speed would be supersonic (320 m/s) at 6700 rpm, and only 89 mph, requiring 48 HP
At a more realistic 230 m/s would be 4800 RPM, 64 MPH, and only 18 hp.
Please Confirm.
At 50 km/h or 31 MPH landing speed - isn't that really fast?
I'm not sure I could land it on our 450' runway!?
Will this bird have brakes )
Realistically, what do you feel is the minimum runway length need for the 50% Eagle?
Great story Thomas!
I'm curious to know the reason for the wing loading test. Was this for certification in Germany?
