Adding to Roger's comments....in full scale boost, or servo tabs assist the movement of the surface against the slipstream. The higher the airspeed, the more effective they are.
They reduce the stick or pedal (rudder) loads felt by the pilot in a mechanical flight control system, by using the slipstream to help deflect the larger surface into it.  They've been used for many years on a lot of airplanes, but of course in RC the very powerful servos and abilities to gang them on a surface negates their benefit.  But as Roger points out, one can reduce the number of servos and power requirements if they are used, and of course properly sized.
Spades, or shovels most commonly seen on aerobatic planes' ailerons do the same thing, although by a different design.  They too, lighten stick loads by using the slipstream to help move the larger surface.
Oh....BTW
@cbarnes0061 .....you meant "Cuervo"....not swervo, correct?
