DA 200
quick question for the DA 200 owners out there.
how much fuel (93 octane 40 to 1 redline, ethanol free) before you said, it was broken in?
10 gallons?
20 gallons?
30 gallons?
i have 9 gallons thru mine, and was wondering if it was broken in. SO far, i have not touched the needles. It is running well, and temps are all under 300 F at the most extremes of maneuvers.
Reason I am asking, I am using a Delro three blade 28 x 12.5
And today should be arriving a new Falcon three blade 29 x 13 & 30 x 12 props for me to test. I think I am getting peak rpm in the air of 6700 , that is when it rips
If I go with the falcon prop, may have more load on the motor, and lower rpm,
Anyone tried these props on their 200?
Funnily enough, I have a very well run in 200 (300 flights) and have just flushed the cans out. It's definitely running better after the de coke of the cans. Yesterday I played with a Biela 30x12 EX 3 blade as well and my normal Engel 29x12x3 and also ran a Mej 30x13x2 Evo NON L. I have to say the Biela provided fantastic thrust and I liked the pace (didn't leave the plane flying at a snails pace like some 3 blade props). The motor had no problem with the load and handled it well in 3d as well as sequence flying. I still really like the Engel 29x12x3 though - although I'm going back to the 2 blade for a bit mainly because the plane fits in my car far more easily with it on, lol.
yakken
What did you use for flushing your cans out.
Caustic soda. I use Zimmerman cans which are stainless steel so it was fine to soak them overnight. Not sure if the same plan would work with aluminium cans.
