Dirt Doctor
I have had lots of "altercations with the ground" but only one from electrical failure and that was a bad Hitec 5955 that stuck in a locked position.  That locked position caused the plane to go into a full right roll that I couldn't overcome but I did get the plane pointed away from the parking lot!  That servo was on the outside of a two-servo right wing - I guess the other 5955 could not overcome the pull of the bad servo. My setup was a JR 12X with one 2.4 1221Rx - with two batteries going into a Smartfly power expander.  Upon inspection of the "carcass" everything worked except that bad Hitec 5955!
The only other electrical failure(s) was due to the battery becoming unconnected due to not securing it correctly (in my early flying days)
The bottom line is that electronics, especially receivers, have become very reliable in the past several years!
