oh58skid
In an earlier post I mentioned that the vibrations associated with the big gas airplanes will cause the tag to switch between the highlight mode and record start stop mode, because there is a feature with the tag that you can tap the top of the tag to highlight a scene or start and stop the recording. I called sosloshot and told them the issue and they e-mailed me back within an hour with the solution......to turn off this function on the tag they said to plug in a USB stick into the base before pairing the devices and leave it plugged in through out the session.
