Drywall is done, plug, lights and switch are done. Next week hopefully I'll get the cabinets and top installed, along with some pegboard,
then I can empty all the storage containers.
I am having eye surgery on the 28th, hoping to see good and be able to work on some things.
Well with the weather the way it is it’s time spend a little time in the workshop. Been building an electric EF1 on and of during summer. But now it is time to get it done. Fuselage is 60% done now adding the stabilizer to the fuselage.
Next figure out the rudder get it built and installed.
@pawnshopmike hope you noticed the hinges.
View attachment 124209View attachment 124210
Looking good brother. Those hinges should work perfect.
One more step closer, the wing is fitted and mounted always hesitant when doing this step of the build have get all 4 bolts in at the correct angle to wing profile and square to the wing. And fuselage. It is done now on to the the stabilizer.
The profile is basically ready to cover at this point. Here is one wing panel with the wing for the EF 60” slick over it. Lots of wing area. I will share a little more now. The plane is based off the Extra NG but being a profile I’m giving it a special name.
Just another day of rain and almost down to freezing. We have had frost overnight for past 3 days. So just have to keep building. So decided to work on fitting the ESC with a cover plate to hold the ESC in place. The cover plate will also work for a battery holder. Just have to finish the front hatch Cover. Then continue with the elevator and rudder.
