More misc work.
Working on the tiller pull pull (?) arm. Not exactly made to plans but close enough.
Very nice work ...am watching closely, and will pinch your idea about battery-holding platforms...much better than stuffing a kilo of foam in to hold it in.....keep up the fantastic work ...and take care and stay safe...
Thanks! I couldn't build a foamie without stealing other ideas. Use any idea you want, probably not mine anyway. 🙃
Working on how to produce the little aileron covers. Not worried yet about an accurate replication, maybe a lost foam shell, then fill the shell with Bondo. Sand the Bondo then glass again, not sure.
I did find the mold but I don't know what happen to it over the years. It has little bumps, not quite sure why but i know it will wet sand out. You can use it if you like.
  • Pulley Cover.pdf
