Have the left wing flap cut off and hinged. Once the epoxy cures I'll finish the linkage and finish the sheeting. Found these PWM switches on Banggood, the two on the top are rated for 8 amps, 3-30 volt, these will control the position lights and the flashing beacon. The switch on the bottom is rated 20 amps, 3-30 volt will control the headlight.
