Scale Stuka Ju87 100in wingspan
Blazing Wings
Horizontal Stabilizer glued into place. Worked on some other details as well. Everything is built, just detailing left and assembly before priming. I might add some scale details if time allows for it.
How do you gel coat after the wing comes out of the mould. I thought you had to gel coat the mould first and then layup the glass and epoxy over the gel coat into the mould
Blazing Wings
You are right, normally I always Gelcoat inside the mold, like with my P40 or Mig3.
However, I did not make molds for the Stuka. But it is not a problem to Gelcoat after the wing has been built.
