A clipped wing Cub won't float like a full span Cub. Looks great though.
Thanks Bart. I have flown both. This one getting some "Flex-Seal" and then going to fly it over a pool of ALIGATORS
It has to set overnight and then the finishing touches. Used JB weld to attach. Need to make the exhaust exit and tail pipe and trim the DLE exhaust stacks back flush with the bottom of cowl
View attachment 110311 View attachment 110312 View attachment 110313
Beautiful job brother.
.It has to set overnight and then the finishing touches. Used JB weld to attach. Need to make the exhaust exit and tail pipe and trim the DLE exhaust stacks back flush with the bottom of cowl
Nice job again but on the first picture what is the black stick or tube doing on the muffler it is at about 45 degrees going up ?
The kit comes in two boxes one smaller one with all the wood and bigger one with the cowl and canopy with a few wood parts in the bottom.
The first picture is the drawings all cut up and taped together so that can be used to build a plane. The following pictures are the boxes opened for the first time and having a look. And the last picture is of the picture on the big box of the plane.
