Not even close to happening.By the way by the time you are all done Acerc is going to make a claim on the cub.
You are more than welcome to join me on this thread it’s all planes
You lucky it does not have a four stroke on it.Great! I am going to install an Aura 8 in the Cub and finish the painting then install dummy engine exhaust.
Something tells me "I don't think so"![]()
Must say the dummy engine really does look good.Well.....Here it is all done with the exception of the scale exhaust. Currently looking for some 1/4" copper tube and fittings.
The only thing I can think off is Stits clear.Thanks Snoop's. I have an idea on why the plane has a not so good glide slope. Yes the 17 pound (wet) take off weight is not helping but this thing should still "float" like a Cub. The stits covering on the wing is painted nicely but the fabric has not been sealed. You can blow air right through it rather easily. I think air is "bleeding" through hindering "lift" under the wing. Going to see if I can find something to spray to seal up the bottom of the wing.
Check out flex seal at the local hardware store!!!!!
