Joshet89
The wing itself was covered pretty much just how you described it so we are on the same page
Where the issue with the tip lies in the total chord of just the wing tip that is glued to the wing is wider than the 24” wide covering I have. So I have to have a seam at the edge of the wing structure to the edge of the wing tip. I did get the white on the tip so the whole wing is covered. Most of the white seam will be covered by darker colors so it should be fairly well hidden. Another step closer today
