Finished the other wing! Turned out better than I anticipated.
Looked over the fuselage, found a wheel axel I had lying around to swap out the bent one. Gear looks good! Patched a couple stick holes in the Ultracote that didn’t hit any structure thank goodness.
LH elevator servo support glue joint failed, re glued it in place... I feel like the servo supports in the tail on extreme flight planes are pretty sub par to begin with I’ve noticed, they could improve that area in my opinion.
Although obviously my situation is different with this plane.
LH elevator tie down ply bracket were de bonding, so re glued those in place.
All I have left is to drill and balance a prop and fix a cowl some how.... at least oil proof it. I’ve never had much luck repairing a factory cowl. Any tips would be appreciated.
If you want to fly it whilst waiting for the new cowl to arrive.......Just wick in some CA on the damaged areas. Use toilet paper to fill in larger holes and cracks. Use accelerator. Gently sand down rough areas. Wont look as bad as you think and it will get you in the air.
If color matters then just use red /white/ blue paint pens on those spots. They are inexpensive at Walmart.
 and swap engines on the Alien since I'm now in the "Removed motors " mode
. Not only can things change in an instant at the field but also in the shop!
