		No sir. Sorry bro.Do you sell Savox servos looking for one Savox SB-2274 sg.
That's what I like about you Kelly. You always find the silver lining!Now I got to build a plow to go behind it. Wear a green ball cap and spit tobacco!.....
Do not know if this is the Correct place to ask but if not let me know. This is about CG. How does CG effect doing a knife edge. I do understand how CG effects lateral balance and how it can effect how your elevator. But when you change the CG how does it effect knife edge. Thanks for your help.
That's what I like about you Kelly. You always find the silver lining!![]()
.If the plane is let's say nose heavy, you need just a tad of up elevator trim to fly level when upright. When you go knife edge that slight up trim will make it pull towards the canopy.Do not know if this is the Correct place to ask but if not let me know. This is about CG. How does CG effect doing a knife edge. I do understand how CG effects lateral balance and how it can effect how your elevator. But when you change the CG how does it effect knife edge. Thanks for your help.
Thanks that makes sense.
Do a Google search for Peter Goldsmith trimming. He did a really good article on it.A lot of what you @49dimes and @Jetpainter have explained is making sense. I really appreciate the help. Making a plane fly level has a lot more effect on all the dynamics of the plane than what I was giving it credit. Getting it to fly level can screw up a few other things in the process. So what I am gathering from this is that flying level must be done with CG movement first with all the surfaces natural or kept as flat as possible. And when that is done as best as you can get it start to mix in elevator with rudder as the final fix for knife edge flying. Thanks.
