Alky6
Edit: Update -- Problem Fixed!
I will try to explain in simplest terms. I also have a request into Horizon support regarding this issue.
I am noticing that on surfaces where sub-trim is used to get the servo arm in the correct orientation for geometry purposes, when changing travel adjust (whether in the servo menu or D/R) and expo adjustments, the centering of the servos (on any surface with sub-trim being used - it is worse the higher the subtrim) change as the travel adjust changes (or expo changes). If I set up different rates for different flight modes, the center point of the surfaces change. Pretty horrible for IMAC when you work really hard to get the plane trimmed out to have it change when the flight mode changes. How have you guys got around that, or is this just a problem with my radio?
I guess one way would be to use programmable servos to set the arm in the correct location (requiring no sub-trim in the radio), but unfortunately I already (a year ago) invested in savox 1270tg's which aren't programmable.
I am pretty frustrated at this point, any thoughts?
Thanks,
-Paul
Thanks,
-Paul
