Yowzilla
I built this today and the first test was better than expected without the use of Thermal epoxy. I have the two part epoxy but wanted to see how the temps were going to get before committing.
It uses 4 each 4ohm 50 watt resistors mounted to two large extruded aluminum heat fins I found on EBay. The resisters are soldered in parallel using 12 AWG black and red wire with nice silicone coating. I used a quality 140mm computer fan powered by 12v of my power supply that is also powering the 308Duo. This is theoretically a 1 ohm resistive load with 200 Watts power handling. The reality is it was a 1.6ohm load measured.
Setting Resistive load at 150 watts heats the base mounting of aluminum extrusion to 170 F while the resistors only measured 135F on the top. This brought 2 - 3S packs down from full charge to a 3.86v storage charge in 4 minutes....Then some balance time.
I will epoxy the resistors in place and test with my Logo600SX 10S packs as soon as I need to....
Most will say....To discharge batteries put something in the air!!!!....
The reason I built this was because of the Texas wind. During this time of year down south the wind will rise throughout the day. If it gets to the normal 30mph before I make all my flights I need to bring my LiPos to storage when I get home....
I also measure my 2 - 2S packs for the 92" Edge just below 4 volts after 4-5 flights, so I regularly need to bring them down as well.
So far I think it works perfect and fast enough without stressing the fragile discharging of the 308Duo.
Let me know if you have any questions and I will see if I can help...
Yowzilla
Yowzilla
