I looked at the diagram some more.  If I need to charge the capacitors, then I need to do it at 50V.  I think I am going to make a extension for the red wire coming off the top pack.  I will plug the two pack together first, then plug in the black to the ESC.  Next plug in the extension which has the extra wire crimped in, into the red wire.  Then plug this extension into the ESC.  This will allow me to use my block connectors on both the ESC connection, and the extra two connection (battery to battery, and this extension) which will add safety from getting unplugged.  If I wire my BEC into the adapter as well, then I can power the plane without arming the motor.  Have to look at the wiring when I get to that point.
