bbrown2828
Gary what is the engine doing,, you said it took 75 flips to get it started, have you done the reed block mod to it , she might be drawing some air,
Looks good GYRO, Hope all goes according to plan, Also thanks for the info on EF 104"
Also where did you get your aircraft work stand? Would like to purchase one.
Thank you!
For the stand, you can build one yourself very inexpensively! http://www.3drcforums.com/content.php?231-PVC-Air-Plane-Stand-Build
Only change I've made to the stand, is that I've removed the foam tape, and installed foam pipe insulation tubing, it's much thicker!
Really looks good Gary with the twin engine. Great job. Looking forward it see a its maiden.
Happy new year!
