	[FONT=Arial, Helvetica, sans-serif][/FONT]
[FONT=Arial, Helvetica, sans-serif]Description:[/FONT]
[FONT=Arial, Helvetica, sans-serif]Here is the all new REDWING RC MXSR 30cc plane. This is a Redwing RC exclusive - and while others may have a similar MXS-R, we revised our prototype several times, before ordering in "whatever" the factory had in stock. Our ELITE plane's are all designed by our team, with one of our advisors being a previous desginer for Boeing. Lot's of great custom features and excellent design for superior flight.
[/FONT][FONT=Arial, Helvetica, sans-serif]
Specifications:[/FONT]
- [FONT=Arial, Helvetica, sans-serif]Wing span: 76" [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Wing area: 1100sq. in.!![/FONT]
 - [FONT=Arial, Helvetica, sans-serif]All up flying weight: 10.5-11.25lb TRUE all up weight [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Length: 70" [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Engine: (Any 30-36cc engine) Recommended: DLE 30, DLE 35, PTE 36 [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Radio: 6 channel recommended (4ch possible) [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Removable stab [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Ringed cowl [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Adjustable push rods [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Canister ready [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Carbon fiber landing gear and accessories [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Painted carbon fiber matching spinner [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Fast fly and easy build features, such as : Pre drilled hinges, pre plumbed fuel tank, pre installed rudder cable, [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Ultracote brand covering (Oracover is the same thing) [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Fiberglass control horns (DOUBLE truss style, not single)[/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Recommended Spinner Size: 3" [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Recommended CG: 5 1/8" from the LE at the root[/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Recommended Prop Size: [/FONT]
- [FONT=Arial, Helvetica, sans-serif]18x8/10, 20x10 for sport [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]18x619x6/8, 20x6/8 for 3d[/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Recommended Throws: adjust to liking as you fly      [/FONT]
- [FONT=Arial, Helvetica, sans-serif]Low Rates Settings | High Rate Settings [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Rudder: 30 degrees, 20% expo | 50 degrees, 35% expo [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Ailerons: 25 degrees, 25% expo | 40 degrees, 40% expo [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Elevator: 20 degrees, 20% expo | 45 degrees, 40% expo [/FONT]
- [FONT=Arial, Helvetica, sans-serif]May Green, 21-043 [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Ferarri Red, 21-023 [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Cub Yellow, 21-030 [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Silver, 21-091 [/FONT]
 - [FONT=Arial, Helvetica, sans-serif]Black, 21-071 [/FONT]
[video=youtube_share;ol4sN0xN__4]http://youtu.be/ol4sN0xN__4[/video]
