Thanks for the measurements Gary, I really appreciate it.Neil: - exactly 130mm across per my calipers
When we get burried in snow I can send you a shipment from my prop box for testing. I am down to my last 24x10TH and they are OTS. I also have these props for 60cc so pick your poison
Mejzlik:
24x10TH
24x10
24x8 evo
Falcon
24x8
24x9
24x10
Xoar wood:
23x10
23x12
24x8
25 3DA
Gary or Matt... did you get an all-up dry weight by any chance?
Thanks... also, my 24x10TH will pull 32.1 pounds at 6570 RPMs and 37.4 pounds at 6900. The Vess 25A (which is closer to a 25x9 than a 25x8) will pull a very loud 41.7 pounds at 6930 on the piped DA60 (RE-2), all at 1.18 Kg/m3 air density... like 80 degrees at sea level.
That's some healthy rpm Gary.Flew again today... And as usual for me, lost a wheel on my first flight of the day. Luckily, I ordered a drill press last Friday night, so I'll cotter pin from here on out.
Landed the plane ok, but the gear stuck in the grass, and damaged at least the sheeting around the gear, and possibly the landing gear plate. Need to dissect and investigate.
Good news was 7500+ rpm in flight on the Falcon 24x10, after leaning a little. Still a healthy mid range burble, so I still need to lean so more.
