E-flite Beast 60e Aerobatic RC Plane, ARF
Tim H.
That looks amazing Tim, might have to put that into ours :)
Let me know if you can't get the upload done, we'll look into it!
Thanks! I'm doing one for Ray's 60" Laser EXP too. Files will be in his build thread. I got the files attached. it REALLY makes the plane look better. That gaping hole just doesn't work...
I'm actually editing the instrument panel to a more scale Beast panel. I found a better pic, but I'm going to do the panel from scratch. I'll post the new one too.
Ohio AV8TOR
Just Do It
Yes looking cool too in draft now. Great work Tim and greatly appreciated.
I haven't had a chance to look threw all the pages yet. But has anyone came up with good hv servos besides the spek ones recommended. I know for the 2 standard ones hs7954 are good. I'm thinking about this bird just want to check out what's need and don't want to empty the wallet.
went standard voltage on ours, with HS-7985 and HS-5245.
For you to go HV, I'd say try the HS-7245MH.
They work really well on all the 60" wingspan planes, so surely they'd be just fine in this application also.
joshgluck
Well that's pretty cool. Is it because there is a servo per wing and you need to coordinate the ailerons in each side?
