Patroller
I think some of this depends on your transmitter. I have a Spectrum DX18 that allows the use of a Powersafe rx that eliminates the need for a Wolverine switch. I am using a Tech Aero IBEC as well without issues. The tuned pipe over the canister definitely make the plane more of a hot rod. That is especially true with the DA120 and the RE2's that I have on my Extreme Flight.
On my plane I am running 3900mah lipos instead of the A123 like you mentioned. This will give you more torque and is comparable with the 7955's that you also mentioned. This is not publicized by Hitec though. The Lipos allow instant feedback of the battery status with on board telemetry and I can easily get five or six flights with plenty of safety room. The only downside is the need to pull the canopy to remove and charge. It's a small price to pay for piece of mine though.
On my EF I used a single rudder servo, the JR MP82T. This is more expensive than the hitec 7955 but provides enough torque to keep the rudder under control with only one on my plane. This definitely helps with setup if you are short one channel and probably a cheaper option than two less powerful servos with a matchbox.
