gregory.da
Ok e-power guru's, I have a 72" , 9.2lb airframe (MSX) that I need to prop. I'm using a Hacker A50-12L V1 that I had on the shelf along with a Castle Ice 100, and A123 for the Rx/servos. I'm going to use my 6s-5000mAh GensAce 30c Lipos that I use on my Velox. I was going to order some 19x8's or 20x6 props, but I've read that the recommended prop for the A50-12L is a 19x10 or 20x10. I have a few questions:
1. Why the 10 pitch, wouldn't a 8 pitch give you more pull for 3D, and the 10 pitch more speed?
2. Will the 20x10 run the chance of overheating the A50-12L?
3. Any idea what the amp draw would be for these sizes/setup? Will the Ice 100 ESC be enough?
4. Should I stay with Xoar PNJ, or is there a cheaper alternative prop with about the same performance/weight for e-flight?
Thanks for your input, DG
