secondchildhood
Nice video. Thanks for the build thread. I ordered one for myself, I like the bigger planes (old eyesight) and like the Epp for the forgiveness ;^)
Dwight
Dwight
Dwight
Ok, finally flew this today. I've got a video, not the best but gives you some idea at least. I used an Exceed Optima 480 and 30 Amp ESC. This is a very good match to this plane. I was flying with an APC 11x7 in the video but plan to switch to 12x6 or even a 13" prop as the motor was not even warm at all after the flight. Battery is a 2200 mah 3s.
Knife edge is easy. Tucked a bit to the canopy but I believe I'm still a bit nose-heavy (just a touch). You can't really move the battery around so I'll likely add a washer or other weight to the tail. It does not need much at all. Knife edge spins were easy to do (sorry, did not capture one on the video) and blenders should be equally good. Inverted did require a touch of down elevator (nose heavy as I said) but that will probably go away when I add the weight.
All in all this plane reminds me of my T-link Yak but better as it's bigger. Sweet plane really for a foamy. I've now owned over 20+ 3d foamies over the past 5 years and this is definitely the closest I've come to the feel of balsa. That's probably because it's fairly large for a foamy at 48" and hence weighs a bit more as a result. Balsa is still better of course (more violent in maneuvers if nothing else) but this is quite excellent. I was pleasantly surprised it had much less of the foamy floating feeling than I feared it might.
Here is my vid. Yeah, not the best but it's something....![]()
Yes, for a profile this is one very nice foamy. I suppose a lot of it is the sheer size of it but it's making me want to get rid of my other profile epp foamies and just keep this one. Still prefer the balsa of course but I won't risk flying those up and down the street like I will this one for fear of damage to the plane as well as it damaging something else.![]()
I just obtained a Swift yesterday. I noticed the manual states everything in high Max) rate. Does anyone have the numbers in inches or degrees for the low and high rate? Would love to get this bird in the air soon. Thanks, Chuck
