wedoitall
Member
If you check Helifreak classifieds, you can find CC ICE 80 & 100 HV ESC's all day long. Those work well with Motrolfly motors
Yes they do
Tom flew Frank's DA60 with the RE-2 on the 25A to 6930 RPMs and 41.7 pounds of thrust on the Rapala digital scale. He flew the Xoar 25x10 Beech the same weekend. About a pound less thrust because of the lower RPMs, but a little more pitch speed, it seemed. I took three videos with the 24x10 Lam Xoar, the 25A and the 25x10 beech, but I think you saw them already, Roger. Frank has the 24x10TH now and we'll get that videoed soon. But I know from experience that the 24x10TH will only pull about 38 pounds at 6900. I'm guess that with the pipe, it may go to 7100. Just not sure.
So I received an email from Ken today about the winds on the 4330 for 12S and 216kv is not the lowest he can go. He said he could do a 195kv for $10 more. So looking at numbers with it on a larger prop look like this. I would be interested in your thoughts.
21x10 on 12S @ 195kv = 3365w - 6.53 flight time with 3,300's - 26.48 lbs thrust
22x8 on 12S @19kv = 3243w - 6.78 flight time with 3,300's - 23.92 lbs thrust
