It's not to bad, I've rebuilt a ton of airplane engines...Mintor, DLE, TMM, 3W, etc etc.. I use to be the Mintor engines North American service tech for 3.5 years.
The first thing you'd want to check is the crank and hub nut, make sure they aren't bent, use a dial indicator to do this. The prop hub retaining nut is usually a booger to get off unless you use an impact, I have a custom prop hub puller I made once the nut is off. Then disassemble the engine, check all parts for damage. Those should be standard size bearing you can buy at any auto parts store or powersports dealer. I like to use the ALL-BALLS bearings(made in USA) I purchase at the powersports dealer I work for during the day. NSK bearings(Japan) are good also.
The bearings should have a number on them like 6203 or S6203 for example, depending on if it's a sealed bearing or not. the nose bearing will be a sealed bearing, the other bearing is general not, open to internal gas oil mix. The nose bearing could be different from the other bearing, so check both numbers.
The bearings will press in and out once you have the crank out.
