Great thanks found the 0.602 tube for the fuselage was also thinking of getting the 3/4 tube from them, but what did you do for a sleeve did you make your own.
Will also use aluminum flat bar how thick and wide. Sorry for all questions but just trying to stock up because it takes time to assemble everything.
One more no sorry two questions do we wait to have the drawings printed till you have the single bolt sorted out. And the second is are PDF sized so that when they go to the printer it will size the PDF to the correct scale.
