3D MOJO 65 w/20cc Build
Luchnia
Only one way to get there and that's to do it. :)
Seriously though when your down low and close to yourself it becomes a lot easier in my opinion. One other thing I learned and everyone does it different but for me when I pop into a hover I look at the tail of the plane the whole time its in a hover. I have found doing it that way I am able to maintain a more stable harrier than if I'm watching the entire plane. Oh and next time we fly together I'm not taking no for an answer, you will fly the "Big Tiddy"
I never really thought about looking at the tail of the plane more. I don't know what I do. I think for the most part I am paying attention to the entire plane and more on the nose of the airplane. I wonder what most others do when they are down low?
Everybody forms their own way. I just found that watching the tail you can see the plane starting to fall one way or the other and catch it sooner. At least that's what I'm seeing.
caf2461
I look at the tail. It is like balancing a broom, easier to do in close.
I have tried others advice and switch to looking at the nose when doing it belly in. It helps but I cannot say I have found a solution that works consistently when doing belly in.
Alky6
All good stuff here guys. Gotta lot of gettin' to it to do.... LOL. Soon. Soon. Lots of learning to do.
Engine mounted, throttle hooked up. Need to finish out the ailerons and fuel system. Can't believe I am almost over the finish line!
I fall in to a trance :trance: and stare right in to the canopy. Thinking I'm inside........Then I start making airplane noises :geek:.
That's what I do down low :ooh?:
Alky6
Fully assembled, dry weight = 8.5 lbs. Ran the engine tonight, started right up after I got the fuel in the pump. Have some things to double check, tighten up, and adjust. Then schedule a maiden. May be a bit before I get there, but we'll see. The tach is only temporary sitting on the fuse. Will pull it off before flying.
