What electrical/switch setup do you use?
Lojik
Hi all,
Thought it would be interesting to see what everyone has in their models to run the servos and power requirements for their aircraft, if you could post here with the below details and I’ll try to compile the results into a nice table below ;)
  • Model Flight Setup: (IMAC/3D/Freestyle/Casual Etc)
  • Model Size: (35,50,100cc or Wingspan in inches or Scale in %)
  • Number of Servos:
  • Number of Matched Servos:
  • Petrol or Elec:
  • Battery Packs used to power servos:
  • Switches used to power on:
  • Safety devices or redundancy devices used:
  • Electronic Devices used to regulate power: (BEC, inteliswitches etc)
  • Electronic Devices used to separate power: (Powerbox’s, powerboards, Powerbus Etc)
  • Any Additional items used to run your power system:
Jack
Lojik
I'll go first
Model Flight Setup: 3D
Model Size: 26% 40cc Twin
Number of Servos: 5 Control Surface, 1 Throttle
Number of Matched Servos: 0
Petrol or Elec: Petrol
Battery Packs used to power servos: 2 x 1300mah Boomarc LifePO4 Lightweight packs
Switches used to power on: 1 x BoomaRC Wallaby Dual Switch
Safety devices or redundancy devices used: Above Switch has built in redundancy, sent direct to RX, Rxcel Optikil
Electronic Devices used to regulate power: None, power direct through Rx to Servos
Electronic Devices used to separate power: None
Any Additional items used to run your power system: 1 x BoomRC Dual Charge Port
Here is what I have in my two of my biggest planes
Model Size: 120cc
Number of Servos: 7 Control Surface, 1 Throttle
Number of Matched Servos: 4
Petrol or Elec: Petrol/Gas
Battery Packs used to power servos: 2x Fromeco 2s2600mAh LiIon or 2x 2s2600mAh LiPo rx packs depending on what I have charged
Switches used to power on: one, through the RCCSKJ Power Box from [MENTION=2470]RedwingRC[/MENTION]
Safety devices or redundancy devices used: Tech Aero Opto Kill switch
Electronic Devices used to regulate power: None, however the RCCSKJ can regulate voltage.
Model Size: 60cc
Switches used to power on: wolverine switch from Fromeco
TimP
How's that power box working out in it? Pretty cool that it gives you the read out so you see what's going on
Feral
Member
My setup is basic as
Extra 260 QBL
5 servos running off a 2100mah life with no switches to a AR8000 rx
8s lipo main packs running Gyro's old Motrolfly.
Basic setup not much to fail
njswede
Aerobeez 88" Slick
Model Size: 50cc
Number of Servos: 6 (5 control surfaces and 1 throttle)
Number of Matched Servos: 2 + 2 (elevator and ailerons)
Petrol or Elec: Gas
Battery Packs used to power servos: 2x 2200mAh 2s LiPo (Glacier)
Switches used to power on: Powersafe integrated switch
Safety devices or redundancy devices used: JR12222 built in Powersafe
Electronic Devices used to regulate power: None.
Electronic Devices used to separate power: None. Feeds directly from the Powersafe
Any Additional items used to run your power system: No
  • Model Flight Setup: 3D
  • Model Size: 88" Extreme Flight Edge
  • Number of Servos: 6 (5 Flight, 1 throttle)
  • Number of Matched Servos: 0
  • Petrol or Elec: Gas
  • Battery Packs used to power servos: 2 Glacier 2600 2S Lipo Rx packs
  • Switches used to power on: Spektrum Powersafe Soft Switch
  • Safety devices or redundancy devices used: Spektrum AR9110 Powersafe Rx
  • Electronic Devices used to regulate power: None, powered by 2S Lipo direct from the Rx
  • Electronic Devices used to separate power: None
  • Any Additional items used to run your power system: RcExel Opto Kill on ignition
