3dmike
20% OFF RC Flite Lighting Systems!!!
[video=youtube;Na496eWhLUI]https://www.youtube.com/watch?v=Na496eWhLUI&feature=youtu.be[/video]
Choose from two models.
KNIGHT:
The Knight was developed for aircraft with wing spans up to 75" and requires a minimum of seven inches of wing tip ground clearance. The X shape directional design uses four 5W high-power daylight balanced LED's per wing and 6061 aluminum alloy throughout. The Knight includes a complete wing tip assembly, easy-to-install mounting hardware and through wing wiring.
We recommend dual 600-1100 mah 2s LiFe packs. The Knight requires roughly 2A of power per wing and provides 340 lumens of light on our sample 71" aircraft.
The Knight weighs 2.4 ounces per wing including wiring. The wing tip hub is 2" x 1.25" with through holes 1.25" apart for mounting.
DUKE:
The Duke was developed for aircraft from 30% - 35%. The X shape directional design uses four 10W high-power daylight balanced LED's per wing and CNC machined 6061 aluminum alloy and 260 brass hollow arms. The Duke includes a complete wing tip assembly, easy to install mounting hardware and through wing wiring.
We recommend dual 1000-1800 mah 2s LiFe packs. The Duke requires roughly 2.5A of current per wing and provided 450 lumens of light on our 104" sample airframe.
The Duke weighs 3.2 ounces per wing including wiring. The wing tip hub is 2" wide x 1.25" tall with through holes 1.25" apart for mounting.
Click here to take advantage of this deal!!!
KNIGHT:
DUKE:
