TimP
NGK Spark Plugs
NGK's Standard Plugs are Constructed for Longer Life and Optimum Performance.
Trivalent Metal Plating Provides Superior Anti-Corrosion and Anti-Seizing
Corrugated Ribs Prevent Flashover
Pure Alumina Silicate Ceramic Insulator, Provides Superior Strength and Better Heat Transfer
Copper Core Aids in Heat Removal
Triple Seals Prevent Leakage
Only $6.99!
Buy some today!
www.redwingrc.com
LEDs for Side Force Generators
These are perfect for our SFGs!
Powerful LED array for Side Force Generators.
These very bright LED arrays are perfect for night flying and can be easily installed into your SFGs with no trouble. The SFGs are made to fit SOME of our planes, but with a little modification you can make these SFG fit nearly any wing with a flat outer edge.
The optimum voltage range for this item is 6.6v to 7.4v.
*Four LEDs provide Optimal light for safe night flying*
$9.99
Now Only $5.99
Just add to cart and SAVE!
Offer Valid Through 05-15-16
www.redwingrc.com
$100 OFF 70cc Sbach 342
Available in 3 Awesome schemes!
70cc Sbach 342
$625
Now Only $525
The RedwingRC 70cc Sbach! The cowl easily fits the PTE 72cc twin, which is an absolute beast and perfect match for this plane. Or pair this 92" wingspan plane with the DA 70 twin or DLE 60cc twin.
The newly designed 92" 70cc Sbach 342 has a slightly longer tail moment and improved aerodynamics to aid in both precision and 3d type of flight.
The 50cc Sbach was such a huge hit and this slightly larger 70cc Sbach is sure is already a winner!
For $100 OFF, at checkout enter code: RWING70
*Coupon only valid with the 70cc Sbach 342
Offer valid through 05-15-16
Happy Flying!
www.redwingrc.com
