Redwing 50 YAK wing servo support triangle blocks
Hello All
I have the Redwings RC 50cc YAK 55 there are triangle blocks taped to the servo plate, I'm sure they are for support for the servo's or maybe the mounting of the plate can someone tell me the exact purpose and location for these blocks?
Thanks and happy landings!
TimP
Yep you are right. Just glue in along side the wood plate that is there. You may have to dremel a little notch for the wire to fit through but will add a lot of strength
wfahey415
3DRCF Moderator
luvdabipes - I have the same 50cc YAK and decided to mount the servos vertically and not use the plates. (Thank you RedwingRC for the option to do this)
I just felt it made for a stronger install. The ailerons on this thing are HUGE and I really didn't trust the thin plate and small screws to hold all that torque. Obviously this is my opinion but that is how I set this one up. BTW: It is an awesome flying airplane. Mine is setup with a DLE 55ra.
