Problem with AR9110?
Av8r RC
Hello all,
Last night me and A buddy started up my 3DHS 89 slick for the first time. All went fairly well getting the DA60 running good. But had an oddity happening with my receiver.
The AR9110 has 3 satellites that must be hooked up in order to work. All 3 were hooked up and had powered the system a few times at the house with zero problems. But last night, like clockwork, the A satellite would flash. The B and R satellites would stay solid. The system was being powered by two, freshly charged 2s 1500 lipos.
Any ideas what could be happening here? It was about 45 degrees out, but the batts should have still put out enough voltage to power the rx.
Hello all,
Are the 2s 1500 lipos completelly isolated from the ignition system?
Av8r RC
Yes. The ignition is running off a NiMh pack. And is hooked up to the receiver via an optikill system.
