New servo has anyone any experience with this servo
Blue Bird BLS-H50B Helical Brushless Digital Servo.
Look at the specifications and price. This is pretty impressive.
Particular Specification
Electrical Specification (Function Of The Performance)
Torque At 6.0V 44.7 kg-cm / 620.8 oz-in
Torque At 7.4V 53.1 kg-cm / 737.6 oz-in
Torque At 8.4V 57.5 kg-cm / 798.7 oz-in
Speed At 6.0V 0.12 sec / 60°
Speed At 7.4V 0.10 sec / 60°
Speed At 8.4V 0.09 sec / 60°
Apply Environmental Condition
Operating Voltage Range 6.0V ~ 8.5V ( 5 ~ 6 Cell Ni-MH or 2S Li-Poly / 2S Li-Fe )
Control Specification
Control System Digital Controller / AD 12-Bits ( 4096 Steps )
Dead Bend Width 0.001ms (1us)
Mechanical Specification
Ball Bearing Dual, Stainless
Gears Type All Steel Alloy Metal Helical Gears
Motor Type High Efficiency Japan Brushless Motor
Horn / Gear Spline 25 Teeth (Same as Futaba)
Outline Drawing
Dimension (mm) 40.5 x 21 x 38.5 mm / 1.59 x 0.83 x 1.52 in
Weight (gram) 83.0 ± 1 grams / 2.93 oz
Product Picture /
Dimension Sketch
S-31A
<Back
They are selling for $104.00 dollars hard to believe
I have to agree with you. If it is the first time in a big plane. Thinking of buying one in a 25% plane on the rudder and trying for a season.
I agree after actually looking at the specs. I saw the name and didn't look much after that.
Flew the mixro servos many years ago. They held up really good! Fast and centered well.
Time will tell on these, if they are worth it or not.
