From Esprit Tech:
With its advanced functionality, telemetry integration and budget friendly price, the Jeti USA DS-6 is a remarkable value and the perfect system for anyone entering the ever expanding Jeti universe!
Engineered to appeal to entry level sport pilots, the new Jeti USA DS-6 2.4GHz radio system has the features needed to fly almost any Airplane, Sailplane, Helicopter, Paraglider, or Drone model. It can also be used as a student transmitter when bound to any of the existing Jeti Duplex 2.4GHz radio systems. One of the most attractive features of the DS-6 transmitter is its full integration with all Jeti Duplex telemetry sensors. You can easily observe different telemetry parameters in real-time, directly on the transmitter using the included JetiBox Mini. A generous 10 model memory and backlit LCD display set this radio apart from other economical systems, while programming remains easy and fully intuitive.
Of course, you will also enjoy all the benefits of the proven, reliable Jeti Duplex 2.4GHz frequency hopping link with its full telemetry integration. Create, manage and program all alarms. Monitor your temperature, speed, battery voltage, receiver battery capacity and enhance safety for both yourself and your model.
Here is what the DS-6 has to offer!
The JetiBox Mini is used to read and adjust data parameters for any JetiBox compatible devices. It’s designed to program and view data of Duplex Telemetry Sensors, Jeti Spin/Mezon ESCs and also works as a servo tester & servo cycler.
$159.00
Visit EspritModel.com
See more posts about Esprit Tech
- (6) Six Channel, (10) Ten Model Memory
- Easy-to-use Pushbutton Programming Controls
- Intuitive, Straight Forward Transmitter Menus
- JetiBox Mini for Displaying Real Time Telemetry
- Stick Mode: Mode 1, 2, 3 or 4 (Comes as Mode 2)
- Servo Reverse, Exponential and Dual Rates
- Programmable Throttle Hold
- Airplane, Heli, Delta, V-Tail Programming
- Compatible with All Jeti Receivers and Sensors
- Adjustable Transmitter Stick Length and Tension
- Jeti Transmitter Compatible Wireless Trainer Link
- Large, Easy-to-Read Backlit LCD Screen
- One Up or Down Programmable Flight Timer
- Power LED Blue Low Voltage Transmitter Alarm
- Powered by Inexpensive “AA” Batteries (4)
- Charge Jack for Optional NiCd/NiMH Battery Pack
$159.00
