From Hobby Zone:
Designed with the beginner in mind, the HobbyZone® Mini Apprentice® S includes an array of features that make taking to the skies easy in spaces as small as your local park. Beneath its durable Z-Foam™ exterior, pilots will find a robust brushless 370-size motor and 18A ESC. SAFE® Technology provides multiple flight modes to progress through and the security of instant recovery at the push of a button. Simply bind your existing 4-channel or higher DSMX-equipped Spektrum radio transmitter and you can take to the sky. A large, easy-access battery compartment makes installing the included 3S 1300mAh LiPo battery hassle-free. When you’ve advanced your skills, optional floats can also be added for dynamic takeoffs and landings from small bodies of water. Get behind the sticks of the HobbyZone® Mini Apprentice® S today and turn your dreams of flight into reality tomorrow.
Features:
- SAFE® technology with Panic Recovery mode
- Beginner, intermediate and experienced flight modes
- Powerful brushless motor
- 4-channel controls
- Durable Z-foam™ construction
- 3S 1300mAh Li-Po Battery
- Tricycle landing gear for easy ground handling
- Optional floats available
Needed To Complete:
Requires Spektrum® DSMX® equipped 4-channel or higher transmitter
Specs:
Approximate Assembly Time: Less than 1 Hour
Approximate Flight Time: 6 Minutes
CG (Center of Gravity): 75mm back from leading edge of wing at root
Completion Level: Bind-N-Fly
Flying Weight: 25.9 oz (735g)
Landing Gear: No
Length: 34.2 in (869mm)
Material: Z-Foam
Minimum Required Radio: 6 Channel
Minimum Speed Control: 18 Amp ESC
Motor Size: 370 Brushless Outrunner 1300Kv
Propeller Size: 8.25 x 5.5
Recommended Motor Battery: 1300mAh 3S 11.1v 20c Lipo
Servos: 4 Included
Size/Scale: Ultra Micro
Spinner Size: 34mm
Wing Area: 341.80 sq in (22.05 sq dm)
Wingspan: 48.0 in (1220mm)
HBZ3180 – $199.99
Visit HobbyZone.com
See more posts about Hobby Zone
