Hitec HS-7966HB Coreless Digital Servo
Status
Not open for further replies.
Drew
Selling a Hitec HS-7966HB Coreless Digital Servo with about one 20 flights on it. Comes with the plastic case and all servo horns like it did new. Looking to get $35 shipped PayPal only please. These are great for a throttle servo and are SUPER fast. Im moving to a HV servo so I dont need this anymore.
Specs are :
Control System: +Pulse Width Control 1500usec Neutral
Required Pulse: 4.8-6.0 Volt Peak to Peak Square Wave
Operating Voltage Range: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C (-4F to +140F)
Operating Speed (4.8V): 0.10sec/60° at no load
Operating Speed (6.0V): 0.08sec/60° at no load
Stall Torque (4.8V): 92oz/in. (6.6kg.cm)
Stall Torque (6.0V): 111oz/in. (8kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Idle Current Drain (4.8V): 3mA at stop
Idle Current Drain (6.0V): 3mA at stop
Current Drain (4.8V): 200mA/idle and 2.0 amps at lock/stall
Current Drain (6.0V): 240mA/idle and 3.0 amps at lock/stall
Dead Band Width: 2usec
Motor Type: Coreless Carbon Brush
Potentiometer Drive: 6 Slider Indirect Drive
Bearing Type: Dual Ball Bearing MR106
Gear Type: Karbonite Gearsr
Connector Wire Length: 7" (178mm)
Dimensions: 1.57" x 0.78"x 1.45" (40 x 20 x 37mm)
Weight: 1.87oz (53g)
Status
