3dmike
Hey guys take a look at what i just got in my inbox!!! Pretty dang cool. I wonder if it will alert you on your phone when it's charged? Of course I would only do this at the field and not at home unless it was in cinder blocks outside! Dang I love technology!
X2 AC Plus - AC/DC Multi Charger
The new X2 AC Plus charger offers expanded capacity and compatibility in a portable and compact package. Dual inputs afford flexible battery charging at home and in the field. And our innovative power distribution mode lets you efficiently assign output power based on individual battery requirements. Capable of charging all battery chemistries, the X2 AC Plus has a built-in 10-amp power supply, internal balancing circuits and 10 different charge/discharge profiles, making it an essential tool for all hobbyists. You can even utilize your smartphone for remote control via an optional WiFi module. Hitec brings the future of charging to your fingertips!
Features:
Twin Channel Charger with Two Independent Circuits
DC Mode Maximum Output 100W Per Port, Total 200W Power
Power Distribution Circuit for Ultimate Flexibility in AC Mode Only
Example 1:
Channel A – 20W, then Channel B – 80W for a Total 100W Power
Example 2:
Channel A – 70W, then Channel B – 30W for a Total 100W Power
Charges NiMH, NiCd, LiPo, LiHV, LiFe, Li-Ion, and Lead Acid Batteries
Built-in 10-Amp Power Supply
Uses Either 11-18V DC or 100-240V AC Power Sources
Adjustable Charge Current Rate of 0.1 – 10.0 Amps Each Port
Internal Balancing Circuits
10 Programmable Profile Settings
Charging Specifications:
NiCd/NiMH Cell Count: 1-15 cells
LiPo/LiHV/Li-Ion/LiFe Cell Count: 1-6 cells
Pb voltage: 2-20 volts
Charge Current Range: 0.1-10.0 amps
Maximum Charge Output: AC 100W / DC 200W (100W per port)
Features:
Compatible with the X2 AC Plus Charger
View, Change & Customize your X2 AC Plus Options via Smartphone
Supports Both iOS and Android Devices
X2 AC Plus Charger | Estimated Street Price - $99.99 | Stock# 44232
Features:
Example 1:
Example 2:
Optional WiFi Module | Estimated Street Price - $22.99 | Stock# 44228
Features:
