Hangar 9 Carden Edition 89" Extra 300 Mid-Wing
Discussion in 'Other Manufacturers' started by brandonduley, Feb 5, 2014.
  1. brandonduley
    brandonduley 30cc
    22
    0
    1
    H9 Carden 89" Extra 300
    My setup is:
    DA-60
    MTW TD75K Cannister
    Falcon 23x8 Carbon Prop
    Tru Turn 4" Ultimate Spinner unlightened backplate
    Spektrum AR9110X Rx
    5- JR 8911HV servos
    JR DS821HV (throttle)
    2- Spektrum 2000 mah Li-Po packs
    Tech-Aero Ultra IBEC
    Danhakl Designs 16oz Fuel Tank
    Graphics by Dennis at Kirby's Kustom Graphics
    Building:
    The only issues I came across were, the elevator servo pockets were not quite big enough for the servo lead coming out the bottom of the servo casing to sit in and not be completely pinched and risk damaging the servo or worse, I dremeled out the pocket slightly to allow for more room.
    I also wish it had come with some anti-rotation pins in the wings, but it did not, so I made up some dowels and light ply pieces of my own and installed them right in front of the rear wing bolt holes were there was already some additional bracing in place inside the fuse.
    To save some weight and improve appearance, I decided later in the build to change the fuel tank out since it is visible through the canopy, I went with the Danhakl Designs 16oz tank, looks much better compared to the stock white tank.
    Flying:
    Didn't get this plane finished until late fall 2013, so I only have 5 flights or so on the plane at this point, thanks a lot winter......
    Having flown 35-40% Carden Extras in the past I was hoping to get a similar flying experience and man was it ever, IMO this plane flies very comparable to it's 40% big brother. Only a couple clicks of up elevator was required and a little bit of knife edge mixing. Can report more as I get more flights on the airframe, but for now I am impressed.
  2. brandonduley
    brandonduley 30cc
    22
    0
    1
    Pics:
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  3. brandonduley
    brandonduley 30cc
    22
    0
    1
    More pics:
  4. gyro
    gyro GSN Contributor
    7,806
    131
    63
    Texas
    Sub'd! Great thread
  5. brandonduley
    brandonduley 30cc
    22
    0
    1
    Thanks [MENTION=3]GYRO[/MENTION]
  6. SnowDog
    SnowDog Moderator
    3,089
    67
    48
    Really nice looking plane and very clean install! looks small next to that DA 170! ;)
  7. gyro
    7,806
    131
    63
    Texas
    Friend has one at the local field, but I've never seen it flown hard :(
  8. brandonduley
    brandonduley 30cc
    22
    0
    1
    Thanks, yeah it does look like a little baby when it's sitting next to it's big brother:)
  9. gyro
    7,806
    131
    63
    Texas
    Got any video of it? :D
  10. brandonduley
    brandonduley 30cc
    22
    0
    1
    No I do not. Whenever it decides to quit snowing and warm up I plan on getting some video of it.
