econpatric
[H=1]Manufacturer Description[/H]
The A10 motors are smalle outrunner of our series and provides great efficiency and light weight.
They’re ideal for small electric airplanes up to 200g (7oz). Featuring a Slotted 12-pole outrunner design. The Curved Neodym-Magnets offer a perfect gap from the inside of the rotor for optimal power and efficiency
The Backmount from Aluminium and Fiberglas, Prop adapter for GWS, STO and APC-Props with needed O-Rings and all screws are included.The motors are available in different Lengths and Windings. Please refer data the data tables to find the right motor for your application.
[H=1]Specifications[/H]
A10-12S
Powerange max. 55W (15 sec.)
Idle Current @ 8,4V 1,0A
Resistance (Ri) 0,185 Ohm
RPM/Volt (kv) 2900 U/min-1
Weight 15g
Diameter 21 mm
Length 21 mm
Poles 12-Pole Outsiderunner
recom. Speedcontroler 4A to 7A Brushless
recom. Timing 20° - 25°
A10-15S
Idle Current @ 8,4V 0,63A
Resistance (Ri) 0,289 Ohm
RPM/Volt (kv) 2320 U/min-1
Weight 15g
Diameter 21 mm
Length 21 mm
A10-7L
Powerange max. 75W (15 sec.)
Idle Current @ 8,4V 1,1A
Resistance (Ri) 0,11 Ohm
RPM/Volt (kv) 2200 U/min-1
Weight 20g
Diameter 21 mm
Length 25 mm
A10-9L
Idle Current @ 8,4V 0,72A
Resistance (Ri) 0,18 Ohm
RPM/Volt (kv) 1700 U/min-1
Weight 20g
Diameter 21 mm
Length 25 mm
A10-13L
Idle Current @ 8,4V 0,39 A
Resistance (Ri) 0,28 Ohm
RPM/Volt (kv) 1200 U/min-1
Weight 20g
Diameter 21 mm
Length 25 mm
[H=1]Owner Description[/H]
This Motor is awesome!
[H=2]Owner Performance Observations[/H]
content
[H=2]Owner Recommend Modifications[/H]
content
[H=1]Photographs[/H]
[H=1]Videos[/H]
insert video links here
[H=1]See Also[/H]
WIKI link
[H=1]References[/H]
insert content reference links & footnotes here
[H=1]External Links[/H]
A10-12S
Weight 15g
Diameter 21 mm
Length 21 mm
A10-15S
Weight 15g
Diameter 21 mm
Length 21 mm
A10-7L
Weight 20g
Diameter 21 mm
Length 25 mm
A10-9L
Weight 20g
Diameter 21 mm
Length 25 mm
A10-13L
Weight 20g
Diameter 21 mm
Length 25 mm
content
content
[H=1]Videos[/H]
[H=1]See Also[/H]
WIKI link
[H=1]References[/H]
