Bunky.F.Knuckle
Looking for some other pro advice. I have a pretty good idea on how this needs to be repaired. Heres to hoping that [MENTION=519]Fixed Wing[/MENTION] and [MENTION=1103]Windecker[/MENTION] chime in with some good advice. I have followed Dean's builds for years and I know Will personally, quite well.
My good buddy [MENTION=248]Wobs[/MENTION] suffered a mid air last month with his primary IMAC machine. He knew Im rather good with a covering iron, so we chatted about me covering his new wing. The guy who covered the airplane, didn't like how Rob built the original wings. So, there was another set of wings bought, built and covered. This was 3 years ago. Now, the time has come to cover this wing panel, and I always look down the LE of the wing, and this time, I seen something I didn't like. Laid the panel on my table, top side down. Sure enough. It had a bow in it. About the center of the span, it has roughly 1/8" to 3/16". I them checked the bottom side of the wing, and from the tip into the root, it shows a little over 1/4". Knowing if these were straight to start with is something I do not know.
Here is my idea..... Dampen the wing, top and bottom. Place the wing in a foam shuck and throw some weight on the panel and let it dry for a period of 24-48 hrs. But I'm also concerned about once I apply covering, that the heat will reinstate some of the bow....
