3dmike
In honor of Aeroworks founder and owner Rocco Mariani 50th Birthday he is giving us a present!!!
Save 50% off for his birthday on the Beautiful 30cc Cessna 195 yellow scheme (now just 474.98)! Rocco has been delivering us great products and great service for over 23 years as the owner and founder of Aeroworks! I personally enjoy every conversation and minute I get with Rocco as he is a blast to chat with and absolutely full of wisdom and knowledge.
Product Details:
30cc Cessna 195 ARF QB
Aeroworks is proud to add the 30cc Cessna 195 ARF QB to their line of Quick Build Series Aircraft. The Quick Build (QB) Series is top quality in both design and performance that has set a new standard for ARF aircraft. Designed with the customer in mind to provide the highest quality, light weight construction and fastest build time possible.
The Aeroworks 30cc Cessna 195 was designed from the ground up to provide a "True to Scale" model with Pre-Installed Navigation Lights, Hidden Flaps and Scale Cockpit. The large wing and flaps make it very stable and easy to fly. Sleek lines, rugged good looks and the Instant Nostalgia are sure to make the Cessna 195 your favorite model.
Specs:
Wing Span 90 Inches
Wing Area 1350 Square Inches
Fuselage Length 69 Inches (Rudder to Front of Cowl)
Fuselage Length 71.5 Inches (Rudder to Front of Spinner)
Cowl Width 8 Inches
Rudder Height with Tail Wheel 17 Inches
Weight 15 to 16 Pounds
Engine 30cc Gas
Engine 1.80 to 2.10 Glow
Spinner Size 2.25 Inches
Radio 6 Channels Minimum
FEATURING:
Strong Light Weight Construction
Professionally Covered in Ultracote™
Extra Ultracote™ Covering Provided for Small Repairs
Scale Lines with Custom Cockpit and Dash Panel
Corrugated Scale Control Surfaces
Pre-Installed Navigation Lights and Wiring
Pre-Mounted Fiberglass Cowl
Pre-Mounted Fiberglass Wheel Pants
Pre-Installed Blind Nuts for your Engine Mounts
Engine Mounting Block and Hardware for Gas and Glow
Aluminum Spinner for Glow Motor Included
Two Piece Wing
Pre-Hinged Ailerons and Flaps from Factory (Ready to Fly)
Carbon Wing Tube
Hidden Control Horns in Tail Section
Hidden Split Flaps
Complete High Quality SAE Hardware Package Included
Adjustable Pushrods with Centering Nut
Custom Throw Meter Included
C.G. Buddy for Easy Balancing
Complete and Detailed Instruction Manual on CD
12 to 15 Hours Assembly Time
Optional Accessories:
Beacon Light
Custom Spinner
Wing and Stab Bag Set
Additional Pics:
Click here for the link!
Happy Birthday 50th Rocco!!!! ...
