2x Hitec HS-7985MG
Status
Not open for further replies.
Anthony7820
I have 2 Hitec HS-7985MG servos. They both have around 100 flights on them as they were on my 71" AJ Slick(Rudder, Elevator)
Motor Type: Coreless
Bearing Type: Dual Ball Bearing
Speed (4.8V/6.0V): 0.16 / 0.13
Torque oz./in. (4.8V/6.0V): 144 / 172
Torque kg./cm. (4.8V/6.0V): 10.4 / 12.4
Size in Inches: 1.57 x 0.78 x 1.45
Size in Millimeters: 39.88 x 19.81 x 36.83
Weight ounces: 2.18
Weight grams: 61.80
Retail Price:$85.00
I will sell them both for $120 shipped or 1 for $70 shipped. Thanks!
Currently they have Savox control arms on them, they are the same spline and fit without any play in the arms; but I have included some other Hitec arms including one metal arm incase you didn't want to use the Savox ones.
Anthony7820
Savöx uses Futaba splines on the output shaft; How did you manage to get them to work?
I put them on and they seem fine after moving the arm back and forth, putting pressure on the arm(without any slop in the arms). Maybe not. At any rate I included some Hitec servo arms with them :)
And here are some more Hitec arms I found in my basement, which I will include.
quadracer
I was just curious, cuz I had a few Hitec arms when I built my 72 with Savöx servos, and couldn't get them to fit. I didn't know if there was trick to it or not.
rcbirk21
yeah...my savox servo arms that came with my savox servos dont look like the ones on the servos, but who cares, servo arms are cheap regardless :D
Anthony7820
Well the ones on the servos say Savox, so they must be Savox. But they do fit on the servo, and I did include other regular Hitec arms with them.
Status
