You can make a swell lift fork on your 1440 lathe.
Big lathe and mill are about 3 miles away at my shop. Almost need a collet for this work.
Some cutting but stopped shy and took the part home to the mini lathe.
Found a mistake in my build and am resolving it this weekend. For some reason I had the wing rear pin area outside of the wing instead of inside. Not to hard to fix fortunately, just needed to find a way to extend the pin from the fuse.
That helped fix another issue as the back end of the cabin wing area was loose. Locking that in finally is a relief.
