3DBuster
30cc
Hello guys,
I am very happy to share with you all our new design, Myself, Yonatan Segev, and Frank Liu worked in partnership from across the globe to design and produce the next generation of freestyle RC models.
Humungous by name and humungous by nature.
Inspired by WW2 fighters with their large spinners and aggressive yet sleek look, the Segev Design Humungous stands tall and proud.
Design and tested over a 12 month period, by leading Aeronautical engineer Yonatan Segev, the Humungous has been perfected to blend precision flight with extreme aerobatic capability.
It’s gentle flight characteristics make the Humungous an easy to fly plane making it perfect for intermediate pilots honing their skills to all out freestyle aerobatics guns seeking an airframe that gives them a great platform to perform.
Choose from three sizes including:
70†– Electric powered
78†– Electric or gas power
92†– Electric or gas power
Complementing the unique lines of the Humungous are a choice of three colour schemes that have been designed by specialised aircraft design guru Ray Younger.
To achieve the sleek lines of the Humungous a combination of composite materials, balsa and ply have been utilised all covered in quality Oracover.
When quality and performance are high on your list of attributes then you will not be disappointed in the Segev Design Humungous.
SPECIFICATIONS - 70"
Wing span 70in/1780mm
Length 72in/1820mm
Weight 3600-3800g (Battery not included)
EQUIPMENT REQUIRED
Motor 2000W, 450-500g, brushless outrunner
ESC 100A
Servo: 3 Standard (ailerons & rudder) 50-70g, 10kg/cm or above, metal gear
2 Mini (Elevator) 5kg and above, metal gear
Battery 6S 4500-5000mah
Prop 19x10E, 19x12E, 20x8E, 20x10E
Spinner 5in Alu spinner is included in the kit.
Youtube:
https://www.youtube.com/watch?v=bC9g6niwfw8
On facebook
https://www.facebook.com/SegevDesign
URL
http://segevdesign.com/Humongous
Length 72in/1820mm
EQUIPMENT REQUIRED
ESC 100A
Youtube:
On facebook
URL
