flycanic
I just assembled a 20cc Aero-plus edge 540 v3 from Mile High RC and was very impressed with the quality of the ARF and the assembled AERO-PLUS tank with the metal cap and heavier duty fitting=s and the thinker material. All the hinges are  the gray ROBART hinge point hinges, the ball links are of better Quality and come with double composite horns for every surface so the ball link is in the center of the horns. Servo's bays in the Wing halves have the covering removed and have a half moon slot between the servo mounting screws for the servo wire to drop through,  and the Light ply used is of top quality. The bottom four fuse formers are reinforced with carbon rods inlaid in the runners, all up flying weight came out at 7.4 lbs  with a new DLE 20
