3dNater
3DRCF Regional Ambassador
I wanted to go out and see what needed to be done to my setup to get more axial rolls... Alas, it was too windy for that kind of tinkering. The poor slick never got unloaded from the van.
I got some longer 1.75" arms for my elevator servos. The geometry works out a little different on this bird so the 1.5" ones I had would only give me about 38* of throw with the end points maxed out. When I installed the new arms I noted that one elevator was binding before it reached 45*. Tonight I re-hinged that side with robarts.
It should be noted that the hinges the factory uses are a white plastic and are much harder. You cannot melt them out with your soldering iron. Well... you can melt them out but when you go to drill out what is left the plastic will not come free. Instead, the softer balsa around what is left of the hinge gives way and you are left with a nasty crooked hole. If you need to re-hinge a surface on an Aerobeez plane just re-drill next to the old hinges. I hope this saves some people some aggravation in the future.
I'm looking forward to my next opportunity to fly this bird with full 3d throws. It should come down in waterfalls a lot faster and burn up a lot less area. It should also give me more pitch authority for entering a hover. If you watch the video you will see that I really had to coax it into a hover last time I went out. It should be a lot more fun now
