clarkj
I miss the 7x14 pace trailer i had. Being as im only probably going to have a 50 &100cc a 6x12 will be sufficient. Should be around $2500
clarkj
In a trailer is the only way i will haul it. I have other things i want to take with me to the field, a parkzone corsair, combat wings, and a 40 size plane i built.
Bipenut53
Close to being done, need to tidy up the wiring inside the fuse, get the throws correct, and balance. The prop should be here today. Pretty well thought out ARF. Here are a few pictures I took this morning.
Bipenut53
Long and skinny, the fuel tank has a zip tie from the front wrapped around the front and tied to the wing tube and the vent line wraps around the outside of the tank to give a loop in the line and cushion the tank. Here is a picture with the canopy off and you can see the tank and ignition module.
