Up to 40% off, So Many Deals!!!
TimP
20% OFF RC Flite Lighting Systems
Enter the world of night flying and never loose sight of your plane!
Normally:
Knight: $139
Duke: $189
On Sale for:
Knight: $111
Duke: $151
RC Flite Light systems were developed with three goals in mind: reliability, performance and durability. These systems are made from 6061 aluminum alloy and 260 brass to offer superior heat dissipation and are extremely light weight. The unique X pattern offers directional light, making the hassle of tail lights unnecessary.
KNIGHT:
The Knight is developed for aircraft with wing spans up to 75" and requires a minimum of seven inches of wing tip ground clearance. The X shape directional design uses four 5W high-power daylight balanced LED's per wing and 6061 aluminum alloy throughout. The Knight includes a complete wing tip assembly, easy-to-install mounting hardware and through wing wiring.
We recommend dual 600-1100 mah 2s LiFe packs. The Knight requires roughly 2A of power per wing and provides 340 lumens of light on our sample 71" aircraft.
DUKE:
The Duke is developed for aircraft from 30% - 35%. The X shape directional design uses four 10W high-power daylight balanced LED's per wing and CNC machined 6061 aluminum alloy and 260 brass hollow arms. The Duke includes a complete wing tip assembly, easy to install mounting hardware and through wing wiring.
We recommend dual 1000-1800 mah 2s LiFe packs. The Duke requires roughly 2.5A of current per wing and provided 450 lumens of light on our 104" sample airframe.
The Duke weighs 3.2 ounces per wing including wiring. The wing tip hub is 2" wide x 1.25" tall with through holes 1.25" apart for mounting.
25% OFF Servo Tester
CLOSEOUT SALE!!!!
Get 'em while we have 'em!
Normally: $14.99
On Sale for: $11.25
GT Power Servo Consistency Master.
With this cool device you can test up to 3 servos at a time for consistency and precision. With the GT Power servo tester you can see how servos react in three different testing modes. Manual, Neutral, and Automatic. Features lights and easy to read labels.
Manual Mode:: Turn the knob at different speeds however you want to check reaction time.
Neutral Mode:: Make the servo go back to the neutral position.
Automatic Mode:: "window wiper mode"- make the servo swing back and fourth at max angle.
40% Opti-Power Backup Batteries
Backup power when you need it!
Adding this neat battery to your plane set up and can save you even after a complete power failure.
Normally: $54.99
On Sale for: $33.00
The ULTRA GUARD 430 is a small lightweight easy to install smart landing system designed to restore total backup control allowing you to land your model safely following a main power failure. This great additional safeguard is easy to fit in your plane setup and features an Ultra Guard high intensity LED Flash Alarm.
Includes:
Battery Pre Installed Circuit Board Super bright LED Warning Lights
Offers valid through 11-8-15
www.redwingrc.com
jhelber08
sweet...I was just looking to get a backup and the scorpion is out of stock...looks like my lucky day :)
